การทำ Cruise Control for 1.8, Topic of the Year 2009 เลยนะ BY.Tommie
Wow Thanks alot Tommie  :D
I remembered you said we need 2 pin connector right?
One to ECU and the other one to brake switch? The link below are 2.54mm pin connector, which I assume is to ECU ?
What about to the brake switch pin connector? I have to buy it also right?
And also for the cable, is it standart cable Tommie? I would like to buy the cable also  :P
Really thank you and sorry to bother you  :D
  • 7 months later...
คุณ ทอมมี่ครับ
ขอถาม 1 ข่อครับ
ตรงที่จาก pedal switch ไปสายไปสีเหลืองที่กล่องฟิวส์
ผมงงว่า มันเส้นไหนตำแหน่งไหนน่ะครับ
รบกวนระบุตำแหน่งชัดๆให้ทีสิครับ
ของมีครบแต่ งง สายไฟสีเหลืองนี่แหละครับ
คุณ ทอมมี่ครับ
ขอถาม 1 ข่อครับ
ว่าเหลืองของ สล็อตไหน มีมีหลายเหลืองเหลือเกิน
คุณ ทอมมี่ครับ
ขอถาม 1 ข่อครับ
ตามนี้ครับ มองเทียบเอา
  • 1 month later...
It's been a while since my last post on this forum, sorry have been really busy lately.
Thought that i should update the progress of installing the cruise control.
The tutorial posted in this forum is indeed very useful and I really appreciate it, but unfortunately I'm still unable to get the Cruise Control to work.
I've tried several time and very sure I had everything right and here's what I've discovered :
    Apparently my speedometer cluster does not support Cruise Control.
    I am driving a honda civic AT FD2 (2009) facelift, with paddle shift ( P,R,N,D,S )
    I did  a diagnostic test on the speedo cluster, and the cruise control light does not light up. It means that the cruisecontrol module on the speedo cluster is not       activated, and cannot transmit the signal to the ECU.
I was told the only way for me to get the Cruise Control working is to replace the speedometer cluster . I'm not sure how much it will cost me and where to buy since my civic have a paddle shift and also VSA.
Oh the audio button is working fine! :)
I'm not sure if anyone here with FD2 (paddleshift & VSA) had the same problem.
Thanks!
  • 5 months later...
  • 10 months later...
  • 7 months later...
