devil_102
การทำ Cruise Control for 1.8, Topic of the Year 2009 เลยนะ BY.Tommie
Wow Thanks alot Tommie  :D
I remembered you said we need 2 pin connector right?
One to ECU and the other one to brake switch? The link below are 2.54mm pin connector, which I assume is to ECU ?
What about to the brake switch pin connector? I have to buy it also right?
And also for the cable, is it standart cable Tommie? I would like to buy the cable also  :P
Really thank you and sorry to bother you  :D
Share this post
Link to post
คุณ ทอมมี่ครับ
ขอถาม 1 ข่อครับ
ตรงที่จาก pedal switch ไปสายไปสีเหลืองที่กล่องฟิวส์
ผมงงว่า มันเส้นไหนตำแหน่งไหนน่ะครับ
รบกวนระบุตำแหน่งชัดๆให้ทีสิครับ
ของมีครบแต่ งง สายไฟสีเหลืองนี่แหละครับ
Share this post
Link to post
คุณ ทอมมี่ครับ
ขอถาม 1 ข่อครับ
ว่าเหลืองของ สล็อตไหน มีมีหลายเหลืองเหลือเกิน
Share this post
Link to post
คุณ ทอมมี่ครับ
ขอถาม 1 ข่อครับ
ตามนี้ครับ มองเทียบเอา
Share this post
Link to post
It's been a while since my last post on this forum, sorry have been really busy lately.
Thought that i should update the progress of installing the cruise control.
The tutorial posted in this forum is indeed very useful and I really appreciate it, but unfortunately I'm still unable to get the Cruise Control to work.
I've tried several time and very sure I had everything right and here's what I've discovered :
    Apparently my speedometer cluster does not support Cruise Control.
    I am driving a honda civic AT FD2 (2009) facelift, with paddle shift ( P,R,N,D,S )
    I did  a diagnostic test on the speedo cluster, and the cruise control light does not light up. It means that the cruisecontrol module on the speedo cluster is not       activated, and cannot transmit the signal to the ECU.
I was told the only way for me to get the Cruise Control working is to replace the speedometer cluster . I'm not sure how much it will cost me and where to buy since my civic have a paddle shift and also VSA.
Oh the audio button is working fine! :)
I'm not sure if anyone here with FD2 (paddleshift & VSA) had the same problem.
Thanks!
Share this post
Link to post
Here I am after a few months and still unable to get the cruise control working on my civic fd2 (2.0 with VSA) :(
Anyone here have any idea? My friend did it on FD1 (1.8) and it is working fine.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
