Tommie Posted July 8, 2015 Report Share Posted July 8, 2015 Let see what I found http://www.aliexpress.com/item/150x-Dupont-Jumper-Wire-Cable-Female-Pin-Connector-Terminal-2-54mm-Good-Quality-DIY-New/1585681815.html http://www.aliexpress.com/item/Top-Quality-1Set-100PCS-Pitch-2-54mm-Dupont-Jumper-Cable-Wire-Female-Pin-Connector-Terminal-UKS/32320067324.html http://www.aliexpress.com/item/New-arrival-1Set-of-100-PCS-2-54mm-FEMALE-Dupont-Jumper-Wire-Terminal-Connector-Pins-Crimp/32319890207.html?spm=2114.32010308.4.82.bNd7JW peqface 1 Quote Link to comment Share on other sites More sharing options...
peqface Posted July 8, 2015 Report Share Posted July 8, 2015 Wow Thanks alot Tommie I remembered you said we need 2 pin connector right? One to ECU and the other one to brake switch? The link below are 2.54mm pin connector, which I assume is to ECU ? What about to the brake switch pin connector? I have to buy it also right? And also for the cable, is it standart cable Tommie? I would like to buy the cable also Really thank you and sorry to bother you Let see what I found http://www.aliexpress.com/item/150x-Dupont-Jumper-Wire-Cable-Female-Pin-Connector-Terminal-2-54mm-Good-Quality-DIY-New/1585681815.html http://www.aliexpress.com/item/Top-Quality-1Set-100PCS-Pitch-2-54mm-Dupont-Jumper-Cable-Wire-Female-Pin-Connector-Terminal-UKS/32320067324.html http://www.aliexpress.com/item/New-arrival-1Set-of-100-PCS-2-54mm-FEMALE-Dupont-Jumper-Wire-Terminal-Connector-Pins-Crimp/32319890207.html?spm=2114.32010308.4.82.bNd7JW Quote Link to comment Share on other sites More sharing options...
peqface Posted July 8, 2015 Report Share Posted July 8, 2015 Is the cable called Dupont Cable? http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20150708032105&SearchText=dupont+wire+cable They dont seem to have long cable, only short like 10cm to 30cm We need like 2m cable right? Also there are also M-F, M-M, and F-F connectors, which should I choose? Thank you Quote Link to comment Share on other sites More sharing options...
chatupons Posted February 22, 2016 Report Share Posted February 22, 2016 คุณ ทอมมี่ครับ ขอถาม 1 ข่อครับ ตรงที่จาก pedal switch ไปสายไปสีเหลืองที่กล่องฟิวส์ ผมงงว่า มันเส้นไหนตำแหน่งไหนน่ะครับ รบกวนระบุตำแหน่งชัดๆให้ทีสิครับ ของมีครบแต่ งง สายไฟสีเหลืองนี่แหละครับ Quote Link to comment Share on other sites More sharing options...
chatupons Posted February 22, 2016 Report Share Posted February 22, 2016 คุณ ทอมมี่ครับ ขอถาม 1 ข่อครับ ตรงที่จาก pedal switch ไปสายไปสีเหลืองที่กล่องฟิวส์ ผมงงว่า มันเส้นไหนตำแหน่งไหนน่ะครับ รบกวนระบุตำแหน่งชัดๆให้ทีสิครับ ของมีครบแต่ งง สายไฟสีเหลืองนี่แหละครับ ว่าเหลืองของ สล็อตไหน มีมีหลายเหลืองเหลือเกิน Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 23, 2016 Report Share Posted February 23, 2016 คุณ ทอมมี่ครับ ขอถาม 1 ข่อครับ ตรงที่จาก pedal switch ไปสายไปสีเหลืองที่กล่องฟิวส์ ผมงงว่า มันเส้นไหนตำแหน่งไหนน่ะครับ รบกวนระบุตำแหน่งชัดๆให้ทีสิครับ ของมีครบแต่ งง สายไฟสีเหลืองนี่แหละครับ ว่าเหลืองของ สล็อตไหน มีมีหลายเหลืองเหลือเกิน ตามนี้ครับ มองเทียบเอา Quote Link to comment Share on other sites More sharing options...
chatupons Posted February 25, 2016 Report Share Posted February 25, 2016 ขอบคุณ คุณทอมมีครับ ดำเนินการแล้วเสร็จ เหนื่อยหน่อย แต่ใช้งานได้ ^ ^ Tommie 1 Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 25, 2016 Report Share Posted February 25, 2016 เก่งมากๆครับ Quote Link to comment Share on other sites More sharing options...
peqface Posted April 14, 2016 Report Share Posted April 14, 2016 It's been a while since my last post on this forum, sorry have been really busy lately. Thought that i should update the progress of installing the cruise control. The tutorial posted in this forum is indeed very useful and I really appreciate it, but unfortunately I'm still unable to get the Cruise Control to work. I've tried several time and very sure I had everything right and here's what I've discovered : Apparently my speedometer cluster does not support Cruise Control. I am driving a honda civic AT FD2 (2009) facelift, with paddle shift ( P,R,N,D,S ) I did a diagnostic test on the speedo cluster, and the cruise control light does not light up. It means that the cruisecontrol module on the speedo cluster is not activated, and cannot transmit the signal to the ECU. I was told the only way for me to get the Cruise Control working is to replace the speedometer cluster . I'm not sure how much it will cost me and where to buy since my civic have a paddle shift and also VSA. Oh the audio button is working fine! I'm not sure if anyone here with FD2 (paddleshift & VSA) had the same problem. Thanks! Quote Link to comment Share on other sites More sharing options...
peqface Posted September 17, 2016 Report Share Posted September 17, 2016 Here I am after a few months and still unable to get the cruise control working on my civic fd2 (2.0 with VSA) Anyone here have any idea? My friend did it on FD1 (1.8) and it is working fine. Quote Link to comment Share on other sites More sharing options...
Ters Posted July 20, 2017 Report Share Posted July 20, 2017 ภาพดูไม่ได้เลยครับ Quote Link to comment Share on other sites More sharing options...
webkhun Posted March 5, 2018 Report Share Posted March 5, 2018 I'm not see picture Quote Link to comment Share on other sites More sharing options...
webkhun Posted March 5, 2018 Report Share Posted March 5, 2018 รบกวนขอรีวิวการติดตั้ง cuis control หน่อยครับ Quote Link to comment Share on other sites More sharing options...
