Tommie Posted January 28, 2014 Author Report Share Posted January 28, 2014 สั่งตอนนี้ไม่ทัน ไม่ทันมาตั้งแต่อาทิตที่แล้วและ คนจีนออกจากโรงงานกลับบ้านกันหมด ไม่ตอบเมลเลย คงต้องรอหลังตรุษจีนทั้งอาทิตย์ละมัง เห็นคนจีนที่ทำรถไฟฟ้าก้อลากลับยาว มาอีกทีกลางกุมภา อุป๊ะ Quote Link to comment Share on other sites More sharing options...
jopathum Posted February 1, 2014 Report Share Posted February 1, 2014 พี่เค้ามานานแล้ว NHK D2S EXCLUSIVE Square hid projector lens has a wide coverage of low beam, colorful sharp cutting line and concentrated full beam. Detail information: 1. Models for xenon bulb:D1S D2S D3S D4S; 2. High light condensing, easy installation; 3. Good vibration resistance and stable emitting; 4. Durable and non-fading brilliant beams. ตัวนี้ใช่Q5ไหมคับ แสงรูปสุดท้ายสวยๆเลย อยากสั่งแล้วคับ พี่ๆจะสั่งกันรึยังคับ ผมขอแบบตูดนะง่ายดี H4 cars models can be installed directly with the unique matching accessories. There is no need to damage the reflector lamp bowls. Its cutting light is perfect. Quote Link to comment Share on other sites More sharing options...
tonsena Posted February 13, 2014 Report Share Posted February 13, 2014 น่าสนใจมาำก rx350 custom curve shield I finally got a hold of the RX350 BX projector, with special thanks to forum member 'paleryeder'. Upon examining the projector, the reflector bowl has the same quality as the rx330, but the front-half lens holder is very Bosch-like, with 4 mounting legs and uses a metal ring to hold the lens in place. It has a flat flippable shield that is not completely straight from side to side. The middle of the shield is higher than the sides, which blocks the reserved highbeam. I have some reservation on this projector already.So I took it out for a comparison test with the the TL bixenon. The RX350 is equipped with an STi-R lens and the TL is equipped with a ZKW-R lens. No lens spacer were used.Again, keeping the same environment settings with my other posts. Car is parked about 45ft from wall. Projectors used 35w D2S 85122+ (no Hg) bulb and 35w Matsushita G3 ballast. Nikon D60 camera manual setting with ISO800, Aperture 1/4', and F6.3. All pictures were taken on the same night (04-15-2011) on a clear sky with a full moon behind building.RX350-BX vs. TL-BX (Distant Shot)Here's an animated GIF:Both have about the same width, but the RX350 has better side intensity.RX350-BX vs. TL-BX (Closeup Shot)Center-wise, the RX350-BX lowbeam is not as intense as the TL-BX. The shield is the culprit, blocking too much light reserved for high beam.RX350-BX: Low and High (Distant)Here's an animated GIF:You can see a dip in the center of the RX350 output. The cutoff beam is not completely straight from side to side.RX350-BX: Low and High (Closeup)Here's an animated GIFThe TL-BX has a better distribution of lowbeam and highbeam:RX350-BX: Low and High (Distant)Here's an animated GIFSo as it stands, the TL is the better projector in terms of center intensity and even spread. I think the RX350 would be a good candidate for a shield mod, making it better than the TL._______________________________RX350-BX With Custom Curve Shield (updated 04.21.2011)I took off the bixenon shield and fired up the RX350 projector to see how light is being distributed. Like other Koito projectors (sk2, sc430, and rx330), the rx350 has similar pattern with high concentration of light in the center and just below the cutoff along the sides:In the pic above, the blue dotted line represents the oem cutoff showing the dip in the center with lots of reserved for the highbeam. The red dotted line represents the modded rx350 with a custom curve shield to make the cutoff straight and thus exposing the reserved highbeam.Oem RX350 vs. RX350-CS (Distant Shot)Here's an animated GIF:Let's see how the TL stacks up against the modded RX350.Oem TL vs. RX350-CS (Distant Shot)Here's the animated GIF:It's an improvement over the 'oem rx350 vs. oem tl' comparison above, with a better center as well as on the sides. Here's the closeup of the comparison.Oem RX350 vs. RX350-CS (Close-up Shot)Here's the animated GIF:Oem TL vs. RX350-CS (Closeup Shot)So there you have it. Enjoy. Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 15, 2014 Author Report Share Posted February 15, 2014 ใครสนใจอะไรมาแปะๆ ไว้ด่วนนะจ๊ะ เดี๋ยววันจันทร์จะส่งออเดอร์ของให้ดิว ได้จัดพร้อมๆเลย งวดเดียว Quote Link to comment Share on other sites More sharing options...
jopathum Posted February 16, 2014 Report Share Posted February 16, 2014 ผมสนใจเจ้าตัวที่ให้คัทออฟตัวนี้คับ 1.อยากถามก่อนว่าเจ้า XGY_2013_newest_D2S_EXCLUSIVE/NHK Q5 D2S ให้แสงใกล้เคียงแบบนี้ได้รึป่าว 2.เชาว Cayenne_B_shrouds 3.รีเลย์ XGY_HQ_H4_HID_Relay_harness_Wiring รวมค่าใช้จ่ายเท่าไหร่ หากเกินงบจะได้ตัดบางตัวออกคับ ขอบคุณพี่ทอมมี่ล่วงหน้าคับ Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 17, 2014 Author Report Share Posted February 17, 2014 อันนี้ของดิว โอเคป่าว 1 Mini H1 3.0" clearlens 35$ 2 H1 Bulb 55W 5000K 18.26$ 3 Ballast 55 W 35$ 4 Shroud cayenne 12$ 5 Pigtail HB4 to CN ballast 5$ 6 Koito waterproof cover 83 mm 10$ sum $115.26 Ship $53.00 Paypal $8.41 Tax $34.58 total $211.25 THB 7,182.53 ZXON 1 Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 17, 2014 Author Report Share Posted February 17, 2014 อันนี้ของโจ เค้าบอกว่าแสงเหมือนกันคับ ตระกูล NHK ใช้ reflect และ Shield หล่อขึ้นรูปเหมือนกันคับ ไม่ชอบเหลี่ยมเหรอ ราคามันเท่ากันเลย ดูไฮกว่าอีก 1 NHK Q5 D2S 60$ 2 H4 harness 10$ 3 Cayenne_B_shrouds 12$ sum $82.00 Ship $53.00 Paypal $6.75 Tax $24.60 total $166.35 THB 5,655.90 Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 17, 2014 Author Report Share Posted February 17, 2014 ตัวค่า Ship ค่า TAX เดี๋ยวได้ราคารวม จะหารแชร์กันอีกนะคับ อันนี้ผมเข้าโปรแกรมที่เค้าให้มาเลยออกมาเป็นออเดอร์แต่ละคน ค่าส่งขั้นต่ำDEPEXที่ 53$ Quote Link to comment Share on other sites More sharing options...
ZXON Posted February 17, 2014 Report Share Posted February 17, 2014 อันนี้ของดิว โอเคป่าว 1 Mini H1 3.0" clearlens 35$ 2 H1 Bulb 55W 5000K 18.26$ 3 Ballast 55 W 35$ 4 Shroud cayenne 12$ 5 Pigtail HB4 to CN ballast 5$ 6 Koito waterproof cover 83 mm 10$ sum $115.26 Ship $53.00 Paypal $8.41 Tax $34.58 total $211.25 THB 7,182.53 อ่ะเคร คับนาย จัดมา ขอบคุณมากๆครับนาย Quote Link to comment Share on other sites More sharing options...
jopathum Posted February 17, 2014 Report Share Posted February 17, 2014 อันนี้ของโจ เค้าบอกว่าแสงเหมือนกันคับ ตระกูล NHK ใช้ reflect และ Shield หล่อขึ้นรูปเหมือนกันคับ ไม่ชอบเหลี่ยมเหรอ ราคามันเท่ากันเลย ดูไฮกว่าอีก 1 NHK Q5 D2S 60$ 2 H4 harness 10$ 3 Cayenne_B_shrouds 12$ sum $82.00 Ship $53.00 Paypal $6.75 Tax $24.60 total $166.35 THB 5,655.90 จริงๆก้อชอบคับ เลเห็นว่ามัน3" ถ้าเปลี่ยนก็คงต้องเลือกใหม่หมด คงไม่ทัน ขอปรึกษาพี่ทอมมี่เพิ่มเติมคับว่ารีเลย์ที่ผมเลือกมันถูกต้องไหมคับ ขอบคุณพี่มากๆคับ Quote Link to comment Share on other sites More sharing options...
zephyr Posted February 17, 2014 Report Share Posted February 17, 2014 โห เดี๋ยวนี้ต่อยอดกันไปถึงไหนแล้วเนี่ย 555 ตามไม่ทันแล้ว Tommie and tonsena 2 Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 18, 2014 Author Report Share Posted February 18, 2014 โจเอาไปใส่ H4 เหรอคับ ถ้าเอาปลอดภัยเดี๋ยวผมย้ำเค้าว่าเอาไปใช้กับ H4 อีกที รูปมันใช่นะ ถูกแล้ว แต่ผมแปลกใจตรงราคา ทำไมเกินหน้าเวบ หน้าเวบมัน 8.5$ เอง เดี๋ยวก๊อบหน้าจอไปให้เค้าดูก่อน บางไอเท่มผมเคยเจอเค้าก๊อบรูดๆเพลินๆมา บางตัวก๊อบต่อๆมา แล้วราคาถูกผิดปกติเราก้อเงียบ ตัวไหนแพงเกินหน้าเวบ เจอกัน 555 Quote Link to comment Share on other sites More sharing options...
jopathum Posted February 18, 2014 Report Share Posted February 18, 2014 โจเอาไปใส่ H4 เหรอคับ ถ้าเอาปลอดภัยเดี๋ยวผมย้ำเค้าว่าเอาไปใช้กับ H4 อีกที รูปมันใช่นะ ถูกแล้ว แต่ผมแปลกใจตรงราคา ทำไมเกินหน้าเวบ หน้าเวบมัน 8.5$ เอง เดี๋ยวก๊อบหน้าจอไปให้เค้าดูก่อน บางไอเท่มผมเคยเจอเค้าก๊อบรูดๆเพลินๆมา บางตัวก๊อบต่อๆมา แล้วราคาถูกผิดปกติเราก้อเงียบ ตัวไหนแพงเกินหน้าเวบ เจอกัน 555 จะเอามายัดในโคมเดิมfdตัวเองนี่แหละคับ ไม่รุ้ว่าเลือกถูกไหม สรุปว่าเปลี่ยนเป็นแบบเหลี่ยมไม่ทันใช่ไหมคับ อีกเรื่องคับพี่ผมลืมลงพลาสติกตัวครอบไฟวงแหวนอ่ะคับ ไม่แน่ใจว่าต้องสั่งซื้อเพิ่มรึป่าว ขอบคุณพี่ทอมมี่ล่วงหน้ามากๆคับ ส่วนเรื่องรายละเอียดการโอนเงิน เดี่ยวpmมาถามคับ Quote Link to comment Share on other sites More sharing options...
tonsena Posted February 18, 2014 Report Share Posted February 18, 2014 โห เดี๋ยวนี้ต่อยอดกันไปถึงไหนแล้วเนี่ย 555 ตามไม่ทันแล้ว เดี๋ยวนี้ของเล่นมีเยอะกว่าแต่ก่อนมาก หาไม่ยากด้วยคุณเกรซ เลยสนุกกันใหญ่ zephyr 1 Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 18, 2014 Author Report Share Posted February 18, 2014 ยังมิได้สั่งดอกนาย แค่ขอ Quotation เค้าไป ตอนนี้ยังสั่งได้ทุกแบบคับ ถ้าจะสั่งเดี๋ยวผมต้อง confirm ราคาและโอนเงินก่อนคับ สั่งเค้านี่คือผมต้องจ่ายเค้าเลยน่ะ ตัว Shroud ตามรูปคับ รูปมีวงแหวน ตัวจริงก้อมี มันเป็นเซต Quote Link to comment Share on other sites More sharing options...
jopathum Posted February 19, 2014 Report Share Posted February 19, 2014 ยังมิได้สั่งดอกนาย แค่ขอ Quotation เค้าไป ตอนนี้ยังสั่งได้ทุกแบบคับ ถ้าจะสั่งเดี๋ยวผมต้อง confirm ราคาและโอนเงินก่อนคับ สั่งเค้านี่คือผมต้องจ่ายเค้าเลยน่ะ ตัว Shroud ตามรูปคับ รูปมีวงแหวน ตัวจริงก้อมี มันเป็นเซต คับผม Quote Link to comment Share on other sites More sharing options...
zephyr Posted February 24, 2014 Report Share Posted February 24, 2014 แนะนำหน่อยครับ projector ตัวไหนเหมาะไปอยู่ในช่องไฟสูงดีครับ เอาง่ายๆ อิอิ Quote Link to comment Share on other sites More sharing options...
Tommie Posted February 24, 2014 Author Report Share Posted February 24, 2014 Mori H1 2.5 ใส่ได้นะคุณเกรซ ปาด Reflec ที่มันค้ำด้านหน้าทิ้งหมดนะ zephyr 1 Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 3, 2014 Author Report Share Posted March 3, 2014 มาอัพเดต เค้าตอบกลับมาตั้งนานละ ดันไปค้าง Junk mail งงเลย เมลบริษัทเค้าตั้งค่าใหม่ เดี๋ยวจะสั่งให้อาทิตย์นี้ละนะ ตอนนี้มีของดิว 1 Mini H1 3.0" clearlens 35$ 2 H1 Bulb 55W 5000K 18.26$ 3 Ballast 55 W 35$ 4 Shroud cayenne 12$ 5 Pigtail HB4 to CN ballast 5$ 6 Koito waterproof cover 83 mm 10$ Quote Link to comment Share on other sites More sharing options...
tonsena Posted March 3, 2014 Report Share Posted March 3, 2014 ป๋า ฝากอันนี้ด้วย 1 อัน ผมทำเสียไปอันนึง ปาดซะเสียของเลย 6 Koito waterproof cover 83 mm 10$ ขนาดเท่ากับของเดิมที่เคยสั่งใช่ป่าว Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 3, 2014 Author Report Share Posted March 3, 2014 ผมกะซื้อใหญ่กว่าเดิมนิดนะตาต้น ตัวเดิมมันดึงๆไปหน่อย ชอบเลื่อน Quote Link to comment Share on other sites More sharing options...
tonsena Posted March 3, 2014 Report Share Posted March 3, 2014 ผมกะซื้อใหญ่กว่าเดิมนิดนะตาต้น ตัวเดิมมันดึงๆไปหน่อย ชอบเลื่อน ผมฝากซื้อขนาดเดิมหน่ะ ทำเสียไปอันนึง จะเอามาทำอีกโคมนึง ข้างเดียวเขาขายป่าวหว่า Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 3, 2014 Author Report Share Posted March 3, 2014 เคๆ เดี๋ยวสั่งให้ เข้าใจละ ข้างเดียวก้อขาย แหละ Quote Link to comment Share on other sites More sharing options...
Ake-fd Posted March 6, 2014 Report Share Posted March 6, 2014 ป๋า ฝากอันนี้ด้วย 1 อัน ผมทำเสียไปอันนึง ปาดซะเสียของเลย 6 Koito waterproof cover 83 mm 10$ ขนาดเท่ากับของเดิมที่เคยสั่งใช่ป่าว ผมฝากซื้ออันนีัด้วย 1 คู่ ยังทันมั๊ยครับพอดีกำลังรวบรวมของจะทำครับ แล้วมันใส่กับโคม 1.8 ได้ป่าวครับ Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 6, 2014 Author Report Share Posted March 6, 2014 มันใส่กับ 1.8 นี่แหละคับ เดี๋ยวรวมๆ อีกที ช่วงนี้ยุ่งนิดนึงทำงานศพคุณยาย เดี๋ยววันจันทร์ รวมแล้วสั่งละ เดี๋ยวดิวรอนาน Quote Link to comment Share on other sites More sharing options...
