Tommie Posted March 26, 2013 Report Share Posted March 26, 2013 Auto Balm ของ Bilt hamber จากเกาะอังกฤษ อ่านดูมันเทพแท้ พอดีเพื่อนชาวอังกฤษจะกลับบ้านช่วงสงกรานต์ ว่าจะสั่งให้ไปไว้บ้านเค้าค่อยขึ้นเครื่องมา มันถูกดี 16 ปอนด์ อันนี้รีวิว ชาวต่างชาติ http://www.pistonheads.com/gassing/topic.asp?h=0&t=813403 น่าสนุกดี I have tried many of these magic products in the past and yet found any that have been close to the claims .With regards to this one in the thread not heard of it , but any polish with cutting compound will remove swirls in plastic / paint etc , i wonder how much added fillers maybe in the compound too .Many people dont realise that alot of compounds and light fine compounds (polishes) have oils to aid the cutting process which temp fill buffer marks marring and fine scratches left by the machine correction process, and only when the panel is wiped down with a solvent to remove this residue the true correction is for all to see.Here is an example of how good some products are now when it comes to masking paint damage using fillers (make up for cars) of course this is not like true machine correction when damaged is removed for good .This is using auto balm paste sealent (2 coats) and thats it just had a proper wash and prep and then waxed .beforeduringremember no machine correction or even cut by hand just applied sealent .I am sure it could be sold as if it has some cut , then worded will remove fine scratches , lets face if you wiped this product across your cars paint surface you would believe it does so , until the sealent washes off in a few weeks/month and you are back with the same damage you started with .Kelly ponsit, macross and werayutsa 3 Quote Link to comment Share on other sites More sharing options...
tonsena Posted March 27, 2013 Report Share Posted March 27, 2013 โห เทพเวอร์ Quote Link to comment Share on other sites More sharing options...
96.5%XX Posted March 27, 2013 Report Share Posted March 27, 2013 เอาเข้ามาขายเลยป๋า ผมสนใจ Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 27, 2013 Author Report Share Posted March 27, 2013 คงไม่ได้เอามาขายหรอกจ้า พอดีเพื่อนจะกลับถามว่าอยากได้อะไรมั้ย เลยเสิชเล่นหาของอังกฤษไปเรื่อยๆกะหาเสื้อบอล555 ดันไปเจอเจ้านี่น่ะ เลนมาถามๆดูเผื่อมันโม้จะได้ไม่เอา เสียดายเงิน 555 แต่เท่าที่อ่านดูหลายๆเวบก้อโอนะคับ ในไทยก้อมีคับ ขายประมาณ 1400 ถ้าซื้อที่โน่น 16ปอนด์800ได้ เงินบาทแข็งมากช่วงนี้ Quote Link to comment Share on other sites More sharing options...
macross Posted March 27, 2013 Report Share Posted March 27, 2013 ป๋าในรูปที่เห็น มันใช้เครื่องหรือมือ เวลาลงน้ำยา ป๋าสั่งเผื่อด้วยได้ป่าวครับ Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 27, 2013 Author Report Share Posted March 27, 2013 ป๋าในรูปที่เห็น มันใช้เครื่องหรือมือ เวลาลงน้ำยาป๋าสั่งเผื่อด้วยได้ป่าวครับ เข้า Link ไปไล่หน้าดูเลยคับนพ มันยาวคับ เริ่มมาตั้งแต่รถเขรอะออกจากสนามเลย Quote Link to comment Share on other sites More sharing options...
sofig Posted March 27, 2013 Report Share Posted March 27, 2013 สนใจเลย พี่ ทอมมี่ เทพๆ Quote Link to comment Share on other sites More sharing options...
macross Posted March 28, 2013 Report Share Posted March 28, 2013 ในไทยก็มีขายน่ะครับแต่ราคาต่างกันอยู่พอสมควร http://www.nutrivision.co.th/product/181073/BiltHamber_AutoBalm.html http://www.nutrivision.co.th/product/181389/BiltHamber_AutoClayRegular.html Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 28, 2013 Author Report Share Posted March 28, 2013 ใช่เลยคับนพ ผมลองสั่งเล่นๆมาจากโน่น กระปุกเดียว ราคาประมาณ 1500 รวมค่าส่ง ถ้าหลายกระปุกก้อคุ้มอยู่ อันนี้สั่งส่งนะ ถ้าหิ้วก้อราคาตามนั้น 16 ปอนด์ Quote Link to comment Share on other sites More sharing options...
next9422 Posted March 28, 2013 Report Share Posted March 28, 2013 ดูทำไมมันง่ายจัง Quote Link to comment Share on other sites More sharing options...
macross Posted March 28, 2013 Report Share Posted March 28, 2013 ใช่เลยคับนพ ผมลองสั่งเล่นๆมาจากโน่น กระปุกเดียว ราคาประมาณ 1500 รวมค่าส่ง ถ้าหลายกระปุกก้อคุ้มอยู่ อันนี้สั่งส่งนะ ถ้าหิ้วก้อราคาตามนั้น 16 ปอนด์ งั้นรอป๋าได้ขอ แล้วให้ป๋า review ก่อนดีฝ่า Quote Link to comment Share on other sites More sharing options...
riisetian Posted March 29, 2013 Report Share Posted March 29, 2013 ตัวนี้เป็นกลบรอยเฉยๆครับป๋า ผมว่าน่าจะหลุดง่ายครับ ถ้าป๋าจะกลบรอย สีขาว ผมแนะนำ Poorboy White Diamond หรือ Dodo Juice Lime Prime Lite ครับ แต่ระวัง Coating ป๋าหลุดนะครับ เพราะมันก็เป็นคลีนเนอร์ในตัวด้วย ป๋าลองสังเกตภาพสุดท้ายครับ จะเห็นว่าฝั่งที่ทำแล้วก็มีรอยเหลืออยู่พอสมควรเลยครับ เพราะมันกลบรอยลึกๆไม่ไหว แต่ผมไม่เคยใช้ตัวนี้นะครับ Quote Link to comment Share on other sites More sharing options...
riisetian Posted March 29, 2013 Report Share Posted March 29, 2013 ตัวนี้เป็นกลบรอยเฉยๆครับป๋า ผมว่าน่าจะหลุดง่ายครับถ้าป๋าจะกลบรอย สีขาว ผมแนะนำ Poorboy White Diamond หรือ Dodo Juice Lime Prime Lite ครับ แต่ระวัง Coating ป๋าหลุดนะครับ เพราะมันก็เป็นคลีนเนอร์ในตัวด้วย ป๋าลองสังเกตภาพสุดท้ายครับ จะเห็นว่าฝั่งที่ทำแล้วก็มีรอยเหลืออยู่พอสมควรเลยครับ เพราะมันกลบรอยลึกๆไม่ไหว แต่ผมไม่เคยใช้ตัวนี้นะครับ แต่ลองก็ไม่เสียหายนะครับป๋า จัดไป Quote Link to comment Share on other sites More sharing options...
Tommie Posted March 29, 2013 Author Report Share Posted March 29, 2013 สั่งไปส่งบ้านเพื่อนที่อังกฤษละคับคุณเธียร รอเพื่อนกลับไปหิ้วมาตอนหยุดสงกรานต์ กะเอามาแปะๆทับ เคลือบแก้วไว้หน่อยน่ะคับ ไม่รู้จะส่งเสริมกันมั้ย Quote Link to comment Share on other sites More sharing options...
riisetian Posted March 30, 2013 Report Share Posted March 30, 2013 สั่งไปส่งบ้านเพื่อนที่อังกฤษละคับคุณเธียร รอเพื่อนกลับไปหิ้วมาตอนหยุดสงกรานต์ กะเอามาแปะๆทับ เคลือบแก้วไว้หน่อยน่ะคับ ไม่รู้จะส่งเสริมกันมั้ย ป๋ามารีวิวด้วยนะครับบบ Quote Link to comment Share on other sites More sharing options...
KARN ~ ~ Posted April 10, 2013 Report Share Posted April 10, 2013 รอดูรีวิวด้วยคนครับ น่าสนใจๆ Quote Link to comment Share on other sites More sharing options...
